Went to go ride today and my victory isn’t connecting up correctly to zwift. Started showing as unknown trainer. When I scrolled to the jet-black section of trainers I didn’t see a victory option? Is it no longer supported?
You’re in the pairing system for speed sensors. You need to pair it for power instead and you will not end up here.
Shut down Zwift, unplug the trainer, plug it back in, run the JetBlack app, and see if the trainer appears there. If it doesn’t, contact JetBlack. If it does, shut down the JetBlack app, run Zwift, see if you can pair the trainer for power.
Thanks much .. working better today
Same issue here but these steps haven’t worked for me.
I can confirm the Jetblack app shows my Victory connected to my local network after power cycling the unit.
Quit the Jetblack app - making sure no devices are connected to the app.
Open Zwift and it sees cadence and speed but Power is just grey and does nothing when I tap it. Disconnecting the speed and cadence does not change the situation.
Swift Companion app shows the trainer.
I am running Zwift on an iPad
Just updating here for anyone in the future.
I had to delete the app fully from my iPad and re-install. Download the app again and login to Swift and seemed to remove the stuck Power Source item.
