@shooji more logs for this problem (I started this topic) . . . Again the Zwift updater successfully downloads many files, but has a checksum issue with one, in this instance, “performance-workout-one [1024x360].jpg”, I have had it previously with different files.
What is with the negative checksum values (see log sections quoted below)?
Setup:
- Windows10 PC (tried with previous or empty \Documents\Zwift folder prior to updating, same error)
- Zwift Launcher: 1.0.52
- Zwift Game: 1.0.100133
Same error:
“Update Failed during patching. Error Code: Z117 at line 602 in Patcher.cpp”
Relevant log sections below; I will try to trace the updater at my home firewall level to see if I can spot anything. Otherwise it is back to the dumb tether to mobile phone work-around.
[7:34:32 2022-01-02] Patcher: Kicking download of missing local files from server…
Then (NOTE: Other files download okay before and after the file with the checksum issue):
7:34:49 2022-01-02] Downloader: “data\Noesis\Blend_Data\Images\Routes\card_route_watopia_roadtosky_1024.jpg” downloaded successfully (local checksum=977320293, manifest checksum=977320293).
[7:34:49 2022-01-02] Downloader: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” downloaded successfully (local checksum=2102473855, manifest checksum=-1614552998).
Downloader: ERROR: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” completed download successfully, but failed the file length test (manifest=283917, written=3995)![7:34:49 2022-01-02]
Downloader: ERROR: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” completed download successfully, but failed the file checksum test (manifest=-1614552998, local=2102473855)![7:34:49 2022-01-02]
Downloader: WARNING: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” failed to download with code: 0![7:34:49 2022-01-02] Downloader: Attempting to try again downloading “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg”
[7:34:50 2022-01-02] Downloader: “data\Noesis\Blend_Data\Images\Workouts\fit_and_fun\fit-and-fun-workout-one[128x45].png” downloaded successfully (local checksum=-1165842173, manifest checksum=-1165842173).
[7:34:50 2022-01-02] Downloader: “data\Noesis\Blend_Data\Images\Routes\card_route_watopia_oceanlavacliffsideloop_1024.jpg” downloaded successfully (local checksum=1230045727, manifest checksum=1230045727).
Another checksum fail:
[7:34:52 2022-01-02] Downloader: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” downloaded successfully (local checksum=-1986470127, manifest checksum=-1614552998).
Downloader: ERROR: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” completed download successfully, but failed the file length test (manifest=283917, written=3995)![7:34:52 2022-01-02]
Downloader: ERROR: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” completed download successfully, but failed the file checksum test (manifest=-1614552998, local=-1986470127)![7:34:52 2022-01-02]
Downloader: WARNING: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” failed to download with code: 0![7:34:52 2022-01-02] Downloader: Attempting to try again downloading “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg”
[7:34:53 2022-01-02] Downloader: “data\UI\WhiteOrangeTheme\JerseyIcons\GarminTacxC32021_thumb.ztx” downloaded successfully (local checksum=-552781718, manifest checksum=-552781718).
[7:34:53 2022-01-02] Downloader: “data\UI\WhiteOrangeTheme\JerseyIcons\ZRacingC_thumb.ztx” downloaded successfully (local checksum=1299316055, manifest checksum=1299316055).
Finishing with this and throwing the error:
[7:35:01 2022-01-02] Downloader: Attempting to try again downloading “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg”
[7:35:02 2022-01-02] Downloader: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” downloaded successfully (local checksum=-1269912225, manifest checksum=-1614552998).
Downloader: ERROR: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” completed download successfully, but failed the file length test (manifest=283917, written=3995)![7:35:02 2022-01-02]
Downloader: ERROR: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” completed download successfully, but failed the file checksum test (manifest=-1614552998, local=-1269912225)![7:35:02 2022-01-02]
Downloader: ERROR: “data\Noesis\Blend_Data\Images\Workouts\performance\performance-workout-one [1024x360].jpg” failed to download with code: 0![7:35:02 2022-01-02] Patcher: ERROR #Z112, FILE “Patcher.cpp”, LINE 602: Failed to download needed server files for update! (Last: “ZwiftApp.exe”)
[7:35:02 2022-01-02] Launcher: Update Failed. Retry attempt 1 of 3[7:35:03 2022-01-02] Launcher: DoUpdateCheck() Called.
[7:35:03 2022-01-02] Launcher: ZwiftApp.exe is not running.
