Recently I have had my IPAD lose the connection to my trainer (Tacx Vortex) mid ride, bringing me to a stop. happened this morning in a race which meant I couldn’t finish the race. Had the trainer and Ipad for about 18 Months now and never had any problems before
I exit, go and select the trainer again and it works fine again. Anyone else had this problem recently?
Thanks for your reply. this use to work fine, the only thing that has changed was a recent update to zwift on my IPAD. None of the recommendations on the link seem to apply.
I am mostly curious to see if other people are experiencing similar problems.
Just to add to this, its not like a drop out. the app seems to forget the trainer and then I have to go into the selection screen where I have to select my power source again. When I do that it works again.
If it was just a drop out I would expect it to reacquire the trainer when the signal comes back and wouldn’t need me to re-select the trainer
iPad user here. Yes!!! Same issue. All connections are a go and then I will suddenly loose resistance. I look down at trainer and I have a solid blue light. Normally it flashes. Have to exit program completely and close app, reopen. Troubleshooting guide no help either.
Hey @KiwiGuy were you connecting your Tacx to another app before starting Zwift? Were you able to try disconnecting your trainer from all other devices completely, then starting Zwift?
@Bug_Riggs this sounds like a slightly different issue where your trainer is still paired but loses resistance. This is an issue we’re tracking with iOS devices currently. Can you send in a support conversation if you haven’t already and include your log files for those rides?
Hey Pieter just looking for an update. Are you still experiencing this problem? If so I’d recommend sending in a support conversation and send in your log files for the rides where your trainer disconnects.
Hello, I am suffering from the same issue here.
3 times today it happened.
While riding I could see my rider just stopping on the side of the road and that’s because there is no connection anymore between my ipad and my wahoo kickr2018. So I have to either go to the menu and look for new connection and reselect the trainer.
But sometimes the trainer doesn’t appear so I have to kill the app and relaunch it.
So you could say that a connection issue but since my garmin watch is still receiving the signal and so does the ipad on the wahoo fitness app I would tend to say that the issue is not here.
Any idea of what could solve this ?
Regis-A: Do you use ZCA (Zwift Companion App) on your iPad?
The same happened to me yesterday (Kickr 18, ZCA on iPad, Apple TV) … just several meters before the top of NY climb all I lost the resistance (afaik there is slope about 15%), my data (watts, HR, cadence) went to 0, and my avatar stopped. There was “No connection” message in pairing screen
I had to close ZCA (double tap Home button in iPad and swipe ZCA out). Then restarted it again and all connections were back and could continue my ride as usual.
I just guess there was a Wifi connection problem/drop between my AppleTV and iPad and I had to restart ZCA to restore it (I use ZCA to transmit all signals to AppleTV) …
@Godmother_Fox thanks you for your feedback but I was not using ZCA. I will try to connect with an ANT+ UBS2 to my laptop since I suspect that the bluetooth connection might be a root cause.
I would like to know if there is a kind of ‘auto-connect’ option in the zwift app which might be of some use here in case of signal lost.
I’ve started to get this too. iPad Air 2, Tacx Bushido - The Zwift app just loses the connection and everything comes to a halt. I have ZCA on my iPhone, but to prevent conflict I didnt try it and turned off BT on the phone and it still happened. Apps are all up to date (Tacx firmware is also up to date).
