Inride and BlueSC
 So, I’ve always been able to pair both my Inride and my Wahoo BlueSC speed and cadence.  Now it’s only letting me do one or the other??  It connects to the cadence portion, but not to the speed; or if I pair with the speed sensor it locks out the inride.  Please advise
I remember having a similar problem with the Wahoo sensor combo some time ago. Replacing the battery fixed it for me.
May not be your problem but worth a check.
Hi Mike,
If you’re using the InRide as a power source, you will not need to use your BlueSC as a speed sensor (since that’s only for “classic” trainers for calculated speed).
