Not a big issue but I thought it might be worth mentioning. For the past week or two I have noticed the post-ride graphic has been a little erroneous. I often do the same Z2 workout which alternates between 67% and 74% of FTP. Normally the 74% intervals are mostly blue with a little green (which should kick in at 76% according to the workout creator function). Recently the 74% FTP intervals have shown as almost entirely green in the post-ride graphic. Not sure if other zones are affected.
I’m Steven with Zwift tech support, and since it seems that was your first post here on the forums, welcome!
To your issue, what you’ve explained sounds potentially buggy, I’d say. But, as James mentioned, that’s only the case if you’re staying well under Zone 3 (Green, Tempo): 76-89%.
If you’re confident there’s no way your efforts should be resulting in the Zone 3 green, then we’d like to investigate that further. See if you can gather up some screenshots and/or video as examples exhibiting the issue, and then send us a support request.
Our team is happy to investigate that further. Thanks!
Hi @Roule_Thoune ! Thanks for bringing that to my attention.
It could be the same issue, but there could also be some notable differences. I’m not sure if these issues with the post-ride report zone colors being off is just for workouts like what David did, or if it includes other SIM mode rides, races, etc.
If David sends us a support ticket with some screenshots and more detailed examples, we can take a closer look at his account, and see if this is already a known issue with an existing bug report, or if it’s a newer development.
