I pad or i phone connecting with monitor
Hi everyone…I should like to known if someone use i phone or iPad connected with an external monitor by HDMI USB C cable…and It Is possibile to use at the Sand time ZC. Thanks for your answers
Sometimes I connect my iPad to my tv using a usb-c to hdmi cable. Works pretty good!
You have a Lightening to USB-C adapter?
I would Airplay it to an Apple TV.
You can’t run both apps at the same time on the same device, you would need a separate phone or ipad to run the companion app.
