I’ve been using Zwift since 2015 as a beta… I started on a wheel on trainer on a cheap laptop.
I’ve now moved house to the UK Countryside with crappy broadband of only an average of 6 mbs.
I have an Elite Drivo one set up with a refurb pc from amazon which has a SSD. I use a 24 inch, probably not HD, monitor and have my ant+ dongle on an extension lead next to the bike.
I also have my phone with me running Zwift Companion App to give ride ons and message.
I’ve built my own rocker plate which is great.
But
Im feeling left out of the Zwift Community as I don’t have connection issues or failing ant+
I’ve tried everything I can think of, but zwift is still working.
I’m in the same boat. To feel included, I think you should just pretend you have these problems and try to spread some negativity where you can. It’s newer cool to feel left out.
I’ve had an extension lead die on me (caused by sweat ingress) but other than that totally trouble free.
There are many common denominators in people who have issues. Most seem to be around Apple and Bluetooth.
You need a little bit of patience, eventually there will be an app update that will allow you to join the whining community. Have faith, it will happen.
In the meantime, you have so many other things you can complain about - I mean, tricycles for April 1st???!!?!!
What do you mean, you can’t run Zwift on a VT100 terminal? ASCII graphics mode needed! (Actually not a bad idea for April Fool’s next year…)
Low-level stuff running quite reliably here as well (as long as I don’t try using Zwift on a Mac again), it’s the physics model doing unexpected things and higher-level stuff acting up at random that annoys me. Well, that, and something like the incorrect Tacx dumb trainer power curves getting released to the users and what that tells about their dev/QA process.
Lucky ■■■■■■■! I‘m zwifting on my son‘s Bobbycar placed on my rollers. The data is tranferred via cb radio morse code which results in a 14 minute delay. I don‘t have a display so I have to imagine what‘s going on in Zwift. And it still works!
