Moin!
Til the last weekend I used Zwift in my Tablet (Galaxy A7) and the Companion-App an my Android (Galaxy S10+).
My bike (ICG 8) was always able to detect my heart rate sensor (Polar H10) via Bluetooth, my tablet connected also to the heart rate sensor via BT und got the cadence and watts form the bike.
The Companion-App also got the infos.
Now, I upgraded my setup and connected my old TV to my Notebook.
So, I’m using my Notebook with an ANT+ Dongle, for the heart rate.
My notebook also gets the cadence and watts data from the bike.
The Companion-App still gets the cadence and watts.
But, the heart rate keeps disconnecting most of the time, even if I’m only sitting in front of my PC.
Also the Companion-App looses now the heart rate sensor
At first Zwift finds the heart rate sensor via ANT+ and BT, but after only a few seconds the connection is lost. Then, after some seconds or minutes it reconnects, only to loose it again.
This happens on the PC (no matter if I connect the sensor via ANT+ or BT) and also on my Android.
The bike has no issues whatsoever.
When I set Zwift to get the data from the Companion-App, instead of the build-in BT, this also happens.
The distance between the heart rate sensor and bike computer is approx 30 to 80 cm (sitting to cycling out of the saddle), to the Android also 30 to 80 cm and to the PC (incl. ANT+ dongle) approx 3 meters.
What have I tried so far?
- putted the Notebook closer to the bike
- changed the USB-Port for the Dongle
- checked the power options
- removed all other BT devices (mouse, headset, etc.)
- changed the Wifi channel of my router
- deactivated my Wifi
- bought a new ANT+ Dongle
- reseted my hear rate sensor
- even tried to persuade the sensor and Zwift on PC
Any further ideas?
PS:
Look at these signal loss:
