Group Rides not updating into Zwift Power
Hello, for some reason I haven’t had any group rides (that usually do go into Zwift Power) update since the 27th July… No previous issues like this at all… any advice appreciated. Thx
It looks like the last (and only) 2 rides you have done since 27th July were set up as group rides, up the Alpe, and set up as 90 minutes duration. You climbed and descended the Alpe so quickly you finished both rides at the bottom in around 80 minutes. To register a group ride on ZwiftPower I believe you need to finish (still be cycling) when the group ride finishes.
Thanks Ian! I didn’t realise that.
