I’ve had my distance goal at 160km forever. In the last two weeks, I’ve gotten the “distance goal reached” banner before I’ve actually finished the goal. Last week it was around 130km (I think… not completely sure) and this week it happened when I hit 100km. A minor issue but what is going on? It shows my correct distance and goal in the companion app.
There is a topic related to this
I suspect the reason why people started reporting it again has something to do with the changes in the Fitness Tracker feature
You should probably also double-check that your goal is still set to what you expect, since Fitness Tracker has the capability to invent a goal for you. For example, I don’t set goals but it gives them to me anyway.
Yes, my goal is correct. In fact, the banner lists the 160km on it, and when I see my goal on companion, it shows that I’ve done 108 / 160km.
I took time out with travel and illness, and somehow got a week goal of 30km. No idea where that came from, but obviously I get that ‘celebration’ early. But the early reward in the past, even when it was set to 200, was a laugh as it happened so often. It did go away, but seems to be back, but not every workout. But we don’t come here for the UI issues. Or do we…
@Heather_MH any idea if this new old issue might be related to Fitness Tracker? It seems like a regression might have happened around the time Fitness Tracker came out, if I am reading the tea leaves correctly.
Likely. It’s been two weeks with this issue.
