Gear shifting issue
I’ve been using Zwift ride since Sept 2024. I went away for 1 week, and now the virtual shifting no longer works. Gears don’t appear on screen, and attempting to change gears does nothing. Wahoo trainer and Zwift hardware are up to date. I use MacBook Air with my setup. No issues in erg mode. Any advice?
Check that virtual shifting hasn’t somehow been switched off in the Zwift settings. Also, you don’t have an ANT+ dongle, do you? Because connecting the trainer via ANT+ will prevent virtual shifting from working.
Virtual shifting no longer appears in the Zwift settings. Yes, I have an ANT dongle, which I’ve been using w Zwift ride since Sept without an issues…
I had a similar issue and the firmware had to be updated on my unit, you can do this via the companion app !
Virtual shifting only works via Bluetooth and not ANT+. So if you’ve accidentally paired your trainer via ANT+ then virtual shifting won’t work.
