Virtual shifting activation gone
I have a Zwift Hub One with virtual zwifting but I can’t activate the virtual Zwifting anymore.
On the settings page the setting for virtual shifting is gone.
Is this on another place now?
Anyway I can’t ride no linger as I can’t shift :frowning:
Many thanks for any reaction or help
Ronny
Is the trainer paired for Resistance on the pairing screen, and is it paired via Bluetooth? Both are required for virtual shifting to work. If you have an ANT+ dongle in your PC you can test by removing it to make sure you’re not using ANT+.
Hi Paul,
Its not a problem of the connection, the other buttons are working fine.
The problem is to activate virtual shifting, I can’t enable it anymore in the settings.
This is a closer view on the settings, there is no longer the possibility to change it here as it was in the past.
In my settings:
What should be:
Steering is on and working but no VS :frowning:
PS; I have Zwift V 1.65 on a Windows PC
Many thanks for any help
Br,
Ronny
What does the pairing screen look like? You do not have an ANT+ dongle present, right? If you pair the Play controllers via Bluetooth, but you pair the trainer for Resistance using ANT+ (or don’t pair it for Resistance) it will do exactly as you describe.
Hi @Ronny_Vanlangendyck, Welcome to the Zwift Forums!
Fernanda here, part of the support specialist team at Zwift.
I appreciate you using this space to bring your concerns about the virtual shifting feature! I took a moment to review your account, and as @Paul_Southworth let you know, it seemed that you are pairing your devices a little bit differently in your last logs.
I was able to verify that you were using the ANT+ connection for power, controllable, and cadence, on the Zwift Hub on your last logs, on the other hand, in the past, you paired the controllable option via BLE, this enabled the Virtual shifting to displayed correctly with the Zwift Plays.
I encourage you to take a look at your pairing process for your next ride! Please connect the controllable option via BLE, and then let us know if the Virtual shifting is enabled once more.
Ride On.
@Ronny_Vanlangendyck just to clarify what Fernanda said, the pairing option you are looking for is called Resistance, not Controllable. They renamed it a while back. That pairing tile must be using Bluetooth. If you have any difficulty sorting it out remove the ANT+ dongle.
Hi Fernanda & Paul,
Thanks for the suggestion.
I removed the Ant+ stick and connected via BT, and guess what, it is working now.
Many thanks for this advice, I’m happy I can ride again :slight_smile:
Case closed
Br,
Ronny
Hi @FernandaA , I’m experiecing same problem as @Ronny_Vanlangendyck ; I have checked that all devices are connect via bluetooth but the virtual shifting doesnt work; I cant enable it in the settings (cant see the option). I have also reboot my mac book air…I have also updated all the devives
Bart, an option could be to connect via the Companion App.
I think a Mac book can’t handle more then 2 Bluetooth devices at the same time.
is there desktop app for the “companion app”?
No via your smartphone
A MacBook can definitely handle more than two Bluetooth connections. Only Apple TV has that limit.
First question for @Bart_Topik - did this work previously and suddenly stop working, or is it the first time you are trying to use it? Which trainer is it and what is the firmware version on the trainer?
I’m having same issue, i cant get my cog to show up on Zwift settings…i am using everything on Bluetooth and i have the cog v2…actually new Zwift bike and cog today…steering works and brakes but not virtual shifting…
this is my situation i didnt realize virtual shifting was a setting since it lets me check my gears etc, but im connected bluetooth with everything updated and ant dongle unplugged there is no setting under hardware to turn on and off virtual shifting…
