When riding, I can’t see wht virutal gear I’m in on-screen and the virtual gears won’t change.
I have a Zwift Cog and Zwift Click.
The Click is successfully coonected and has high battery power - when I go into the tutorial and press the + and - buttons it responds and ticks the boxes.
I’m running Zwift Hub paired through ANT+ on a laptop.
Companion App is on on my phone, Bluetooth and Location are turned on.
Bluetooth on laptop is turned on.
My son rides with the same set-up on iPad - and doesn’t have this issue.
Virtual shifting requires pairing the trainer via Bluetooth
Thanks - that’s fixed it.
Although my bluetooth connection keeps dropping out which is why I use Ant+, so that’s another issue to resolve
You have two choices for Bluetooth pairing: direct to the PC or bridged via the Companion app. Try both and see which works better.
Same here, great when it works but keep losing the Play and trainer on BT on the laptop (probably not a great internal BT card on it). Am going to try the bridge on the app/phone and otherwise could try a second USB extension (always used one for ANT+) and getting a BT dongle nearer the trainer and the Play I guess
