My speed gear isn’t visible on my appli when it’s working.
It’s connected and Z is blue.
Who could help me?
Thank you.
Are you able to shift virtual gears - you feel the gear change - but you just don’t see the gear indicated on your screen? Can you attach a screen shot of what you do see?
What equipment are you using - Zwift Ride, Click, other?
Hi Tom, thank you for your answer. I can’t change even if i press the shift. I was always with a same gear.
Yes i use Zwift ride click.
The trainer is paired via ANT+. You must pair it via Bluetooth
