I’m running Zwift (iPad version) using a Wahoo Kickr but Zwift can’t pick up any signal from my Garmin cadence sensor. However, I have no problems running Zwift on my Macbook Pro and all sensors show up fine.
Do you know what’s causing the candence show to not show up on iPad?
Yes, my Garmin Ant+ key is connected to a USB cable into a lightning to USB adaptor. Other than the USB adaptor, it’s the same set up I use for my Macbook Pro.
I believe Zwift only supports the Wahoo Ant+ Key for now:
IOS: Wahoo ANT+ dongle support for Power Meters, Cadence, Speed, and Heart Rate. Zwift will not control controllable trainers over ANT+ in this release.
Paul is correct. You either have to use the Wahoo ANT+ dongle + lightning to 30 pin adapter or the Viiiva HRM as a bridge. No other setups are compatible yet.
