I agree. Had the same issue. Interestingly it only occurs with the 50% and 75% climb grades. I was able to complete the climb at the 100% and 125% without getting coned.
It must have been about timings then, I did it at 100% (1m35s)
No, I wish I had one
If you are riding a time trial bike and enter an event or race that does not allow time trial frames, the default bike is the Zwift steel bike.
Sometimes an update will change your jersey back to the original Zwift Jersey.
Some weird graphic anomalyâŚ
Ending an event, like The Big Spin, shadows and highlights and stuff change in the world. It looks kind of bizarre, like the time of day suddenly shifts. Iâm running 1.109 on Windows 11 at Ultra UHD using GeForce 1650 Ti.
It was captured in the video screen recordings:
Is it just me or is the workout sync with TrainerRoad broken? My scheduled workouts on the TR calendar are not syncing to Zwift (e.g. today and tomorrow). It used to be synced in seconds in the past.
I tried to disconnect & reconnect TR and Zwift but it did not help either.
Anyone else has the same issue?
Hey Martin - Looking into this for you. Did the TR workout eventually show up in Zwift?
It did not. I just finished my session and used TR app from my phone.
Not sure what side the problem is - if Zwift or TR. When I look into the TR app, it does not show the usual Z-icon that it is synced either. See below.
Thanks Martin, weâre looking into this. Once thereâs an update I will post.
Edit - Weâve worked with the TrainerRoad team, and changes should be propagating out soon. Expect your workouts to be syncing again over the next couple of hours.
Hey all, this should be resolved now. It looks like we had a period of time where TrainerRoad wasnât sending workouts to Zwift. Itâs corrected now, and Iâve confirmed on my own account that I see my workouts coming through again.
Confirmed! It shows as synced now ![]()
@shooj @John_Zwift - why is the âSend Group Textâ field length so significantly smaller than what you can do on the Companion? I couldnât even describe all of the Stage unlocks for The Big Spin in one line when doing CTRL+M on the PC. This has been annoying for eons.
Still broken and zwift REFUSE at acknowledge itâs still an issue
Isnât the thread you linked to about an an issue where some users had no resistance when directly paired via BT, and worked around with pairing via Companion?
That issue seems to have been fixed. But it sounds like your issue is different, so youâre chasing the wrong thread.
I am wondering if it was intentional to remove the coffee breaks from banded meetups. We have a rider in one of our banded meetups who really, really needs those coffee breaks due to major health issues. Why was this change implemented?
Launcher version 1.1.14 is out of date. If you see that issue with a current version of the launcher then itâs worth reporting. https://www.zwift.com/download and get a fresh version.
Ah thanks. Odd that it never pushed.
They donât push out every launcher update, or sometimes they let it soak for a while before pushing it out. In the case of 1.1.16 supposedly that is coming but it hasnât happened yet.
