Game Update v 1.109 [March 2026]
Hi everyone,
Phased rollout of game update 1.109 begins today to macOS / Windows / Android machines.
Phased rollout to iOS / tvOS devices begins tomorrow.
  • Mystery Spinners have arrived in Watopia! From now until April 19, explore Watopia to find them and unlock prizes from Big Spin’s past. Find them by spotting an orange road marker with a question mark. Happy hunting!
  • Fixed an issue that could cause Zwifters to not receive the correct amount of Bike Upgrade progress after teleporting multiple times.
  • Fixed an issue that could cause estimated route completion time to be inconsistent between route cards on the home screen and the route details sidebar.
  • Fixed an issue that could cause flickering colors in Makuri Islands.
  • iOS: Stability improvements.
  • tvOS: Improved stability when loading Zwift.
UPDATE March 11
Phased rollout continues to Windows / macOS / Android.
Phased rollout to iOS/tvOS begins today.
UPDATE March 12
Phased rollout is complete to all OS platforms.
Do you have questions or issues to report? Let us know below.
There’s something wrong with the Koppenberg portal (France). I did ~8 w/kg for ~95” and it gave met the cone of shame. When finishing the climb, the timings said 0:00; 500w.
You should contact support. I’m unsure if it’s a problem with the portal climb or simply triggered by the power numbers.
Njal pedersen put out 8.6wkg in the peaky pave race yesterday for 120seconds so its possibly the power numbers as he’s a verified user that the numbers stack up for him but not the user above
How do I become verified on Zwift? I have plenty of verification on MyWhoosh because of SRC (both in cat 1 & 2). It’s not like these power numbers are that crazy right?
I would start by emailing zwiftpower@zwift.com
Apple TV, iPhone and iPad users please note phased rollout has begun to your devices.
Yet, the incorrect distance to route completion on the mini map bug still persists after MONTHS yet its not fixed.. Priorties I see
For semi professional no
Did you use a feather or two? That would lower your weight and potentially put you in a reading of too high w|kg.
Hi everyone. Please update at your earliest convenience.
Also flagged with cone of shame on Koppenberg… albeit for little over 6wkg.
1.5 feathers used.
Also resistance issues again (kickr v6)
Mentioned above. Can you ride again but without using a feather?
Resistance on my kickr (2017 version first, v6 since summer 2025) has been terrible since at least april 2025. And that’s talking about ERG mode and behaviour when shifting. Not even talking about the sticky watts issue many users experienced here.
My M1 MacBook Air installed this update this morning and I was having issues with lag in response to shifting and cadence changes with my Zwift Ride / Zwift Hub combo. There was a 2 second or so delay vs normal. For example my avatar kept pedaling for a couple seconds when I’d stop to try to super tuck and then took a couple seconds to start pedaling again when I was pedaling. Similar with changes in gears getting to the correct resistance.
Edit: I installed the new launcher and restated everything and it was back to normal.
How did you establish that it’s not a problem with the trainer? I’m not saying you are wrong, just wondering what you did to prove that it’s not the trainer. (I assume you are referring to this topic: Bad experience with ERG mode since April)
I am indeed referring to that topic. I assumed it’s Zwift because it’s happening on two trainers. First on the Kickr v3, then I upgraded last summer to a Kickr v6 and it’s still the same. It could be a coincidence that the Kickr v3 went bad and then I got a brand new bad Kickr v6 showing the same behaviour. Zwift support hasn’t exactly been helpful in trying establishing the cause either.
Updated this morning and had issues.
  1. My bike was set to the Zwift steel instead of the bike I’ve been riding (didn’t realize until race time)
  2. The event that I had saved on the companion app wasn’t showing in my events
  3. My HUD was reset to only show cadence and heartbeat
