Game Update v 1.107 [February 2026]
Yes, I always close the apps and then power off the Apple TV.
That screen was grey on the right side, but the screen before that was just a spinning wheel when trying to save
This hasn’t been reported as a widespread problem. Which model of Apple TV is it? Is it the A1625? You can check in the General section of Settings.
It’s a 4k, I’ll see what version next time I turn it on.
It’s done it on tvOS 26.2 and 26.3 now, it’s never done this before the 107 update
it work. i did, today.
I am having the same issue as others. The game starts and plays fine initially. Then the screen freezes after 2-4 minutes. The game continues to run, however, and using the companion app, I can see where I am on the map, power, speed, heartrate, resistance transmits, etc.
Dell Inspiron 7539 13 - i7-6500u - HD 520 graphics - Windows 10
I went to the Intel link provided, and attempted to install, but I get an error that indicates that I need to go through the Dell Support path rather than through Intel directly. I then tried that route, but didn’t see a driver available from 2022. Any ideas?
I had a similar error when I tried to install the 2022 driver over the existing 2018 driver, but after uninstalling the old driver and a reboot, I could install the 2022 driver (I used ā€œrun as administratorā€ but don’t know if that was required).
Thank you for your service
Is it worth leaving the update at this stage
So, here Zwift freezes (or mainly: is very very slow) in the pairing screen. Once i pass the pairing screen then Zwift works normal. But if I fo back to pairing then Zwift will freeze first and then very slowly open the pairing screen (same when clicking on something in the pairing screen.
I am on a Windows 10 (KB 5071959), Intel core i7-2600, 3.40Ghz, 3701Mhz, 4 core, 8 processors.
Do you happen to have an ANT+ dongle in that system? If so, test with it removed. Very slow pairing screen performance can be associated with that. You may also be able to plug it back in and continue.
Yes and the pairing screen is working well once i removed and put it back in. Do you know why this is happening and do i have to remove the ANT dongle everytime?
Probably not. This is an old bug. Now that you know about it hopefully you can work around it and have happy rides.
The climb HUD is off on at least some routes.
Distance to completion bug still there too
I’ve experienced an awful lot of application crashes since I updated to this version. I feel like I’ve barely had a crash in 8.5yrs of Zwift, but I’ve had about 7 or 8 in the last week. Each time it’s a full cut-to-desktop and have the application exit.
3 of them have been within the first few minutes of the ride, and seem to occur when I’m bringing up the pairing menu whilst riding. But other rides are seemingly random. I had 1 about 15 mins into a ride in New York, and 3 crashes in France; 75 mins, 40 mins & 25 mins into a route. Not ideal as I was looking to complete the final TdZ stage for the Ultimate Challenge. In the end I used my phone as the Android app seemed stable.
Recorded the logs for the first few and submitted them, subsequently done a windows update (Windows 11), refreshed the Nvidia Graphics drivers turned off OneDrive syncing in case it was interfering with the .fit files, and also switched to bluetooth connections (physically unplugging the ANT dongle). All to no avail.
Laptop is a 2024 Razer Blade 16 (Nvidia RTX 4070, i9-14900HX, 16GB RAM & 1TB SSD).
Try uninstalling Zwift and reinstalling. Be sure to delete all the folders/files after uniinstalling. Full procedure is somewhere in the forums.
Hi, I have had issues wirh both Dell Windows 10 laptop and Surface Pro 4, with feezing at some point aftwr starting ride, son’t have to do anything, just leave it running and it eventually crashes. Did tey rolling baxk windows updates and reinstalling windows but to no avail. Will try the driver update recommended tomorrow
Likely it’s this driver issue:
Hey @calfzilla - Is the distance completion an issue with pace partners only? If so, do you notice it every time or with certain pace partners? We’ve made some improvements here, but it’s not fully fixed based on your experience.
Next time you notice it, can you let me know which pace partner and time you noticed it? Also, if you’re teleporting between pace partners can you note how many teleports roughly have happened when you see this?
