Game Update v 1.107 [February 2026]
Hey @Henry_Ashman_2168 - I see a couple of these in our system. I’m going to get the right team to look at what might be going on here.
As a workaround until you find a proper solution, you might be able to run Zwift on the iGPU instead of the Nvidia GPU. Reading some comments about that laptop, you may not see the iGPU available without turning on Optimus mode in Nvidia settings. I don’t have one so I am hand-waving a bit here. Check Windows Display settings to see if you can put Zwift on the iGPU if you’re interested in trying that.
I haven’t noticed it on a free ride, or at least not for quite a while. I don’t recall seeing it in events. I pretty much only ride with Coco and Yumi for pace partner rides. The most recent time that the screenshot I attached from 5 days ago was with Coco. I almost never use teleport, and none of the times I’ve seen the route completion distance issue have had a teleport involved (other than the automatic one when starting the ride to get me to the pace partner). If it happens again I’ll report back.
