Game Update v 1.107 [February 2026]
Yep it is that same problem with Zwift on HD520 integrated graphics. You should try that 2022 Intel driver and see if it helps.
Same issue with me. Running on a Surface and screen freezes after about two minutes. Still audio, and my data still shows in companion, but screen freezes. First time was mid ride in Yorkshire immediately after update. Now it is basically two minutes. Froze this the pens this morning, then I uninstalled and reinstalled and did a late join. Froze shortly after.
Follow this topic if your system has the Intel HD520 graphics: Windows 10 freeze on Surface Pro 4 + Windows 10 [February 2026] - #4 by Paul_Southworth
I have the same, everything freezes after few minutes. What a mess
Did you install the driver mentioned above?
Are you planning on updating the duration of workouts and events to display “min” instead of “m” at some point? It has bugged me ever since I first got on Zwift since “m” is the SI term for meter, and “min” is the proper abbreviation for minutes.The first thing I did on Zwift was an FTP test and I remember wondering why it was only 39 meters, or if the “39m” (meters) was the length of each section until I realized that it said duration below it. But to this day I always read it as meters first and then remember it’s trying to say minutes.
I updated to that new intel driver referenced above and all good now! Thanks!
Since the update the app constanly freezz after few minutes!!!
I uninstall a d reinstall didnt work!!
Running on windows 11
What is the CPU and GPU in your PC?
I have the same problem. My windows 11 pc freezes at the pairingscreen….
That might be this problem caused by Windows updates: Zwift freezing during startup and locking Windows [January 2026]
Describe the PC specs and you might get more advice. It’s not enough to just say “Windows 11” since problems are often specific to the hardware.
No time to put on the sprint jersey. :sweat_smile:
The new 107 version is crap! I did all the things Zwift wanted to keep the program from freezing. 1:28 later, FROZEN again. Either roll back the update, fix the bug, or I am out of here.
Yep, after today’s install the first training was ok. Thanks
freezing issues continue after all the grapihcs card issues have been fixed no error in the log randomly freezes last time it was 39min in to the ride
Will people with Emoji’s in name be able to ride through Makuri finish lines without crashing again?
@Matt_Wheeler i will test it in about 12 hours from.
Is anyone else having trouble ending a ride / workout on Apple TV?
Twice now I’ve come to close my ride and it’s timed out saying it’s been saved locally , no issues with the connection etc as I can see other rides whizzing past in the background and other apps are working. 150mb mesh connection.
Tonight the ride uploaded after relogging in to Zwift, but it’s not made it to training peaks or strava
Do you always force-quit the Zwift app after each session, rather than leaving it running in the background?
Just finished a ride closed ok if yoor talking about the last screen that tells you the work you’ve done mine has been messing about
