No, the app update will only appear in the Play Store for you when the phased rollout has reached your system. What you’re seeing is just a small delay between the update being available and your phone noticing it (assuming your apps are set to automatically update). This is normal.
Thank you for confirming
Game version 1.103 is available to all. Please update at your earliest convenience.
Wish the escalator bug in NY would’ve been fixed before the last ZRL race… ah well, just have to live with getting dropped and lose a bunch of vELO
What issue? Draft effect isn’t a function of grade.
[Edit:] Draft effect shouldn’t be a function of grade. It’s an aerodynamic thing – has nothing to do with gravity. Please explain what you mean. What is changing?
That topic should answer your question, but comment over there if you disagree
I see the camera 1 bug is still alive and well, @shooj. Any updates on a fix here? Been asking for three years. Thanks.
Quando ci saranno le scritte in italiano durante le sessioni di allenamento?grazie
Apple Watch is not connecting properly again. When I’m in the pairing screen, it gives me the option to pair to Apple Watch but after I do, it says “unknown device”. Sometimes I can pair it for a few seconds but it drops out soon after.
I’ve tried all the tricks I have (Been using Apple Watch with Zwift since 2021 so I know the issues) and it still doesn’t pair consistently. I’m on iOS 18.6.2 using a iPhone 15 to pair to an iPad via Apple Watch.
Have you already tried using HeartCast or Echo to make the watch broadcast HR? The watch integration is not supported by Zwift anymore so I’m not sure they will do anything to help you.
It worked 6 days ago. What changed? This happened awhile back, they realized something had changed and rolled it back.
No idea. Since they dropped support for it a long time ago, my guess is that changes are not tested with the watch. It’s a zombie feature that nobody should rely on.
Don’t know if it’s just visual oddity or if it’s physics too, but today mine and other rider’s avatars were adopting supertuck within a bunch, when there were riders ahead of them, under supertuck conditions (greater than 57kph on 3%+ descent gradient and very low/no power).
This was in the James Bailey rubberbanded group ride on Surrey Hills on Friday 5th December, that began at 1330 UTC.
The latest comment on Eric’s drafting updates article writes about experiencing the same thing in a different event.
Maybe there’s no draft in a banded ride? I wouldn’t bother thinking about pack dynamics in a banded ride.
No idea, just looked really weird seeing supertuck in middle of a group, when I’ve not seen that for months/years.
It’s physiologically impossible to measure heart rate at the pulse anyway, you can only ever measure pulse rate (and no heart and pulse rate are not identical)
Updated in the background while I was using and then app crashed while I was mid interval and lost progress ![]()
Time to vote for the topics above
Interesting - but do you get complete dropout of the trainer connectivity (no power reading) or just the virtual gearing issue? For me this was the first and only episode of virtual gearing only failure - power was still showing on the screen (hence this was not a simple network connection issue). This issue has not happened again. I hope it was just a one off.
Sometimes I get full trainer dropout of wifi, other times it’s just virtual shifting.
