Works fine with a USB Bluetooth dongle, I trialled one that cost me the princely sum of £1.79.
Can you please explain what this is? I have an issue with my Kickr V5 that has recently appeared where on some descents (and perhaps on some ascents) the resistance is wrong e.g.far too high on a descent section
Yay! Thank you Zwift!! Please another ST MTB course.
Can we switch routes without quitting or having to set a meet up now?
Any update on when zwift will be fixing the issue with the Windows Intel graphics drivers causing the program to freeze and crash? Can’t even use my laptop for this as zwift is far behind graphics drivers. Would think you would want to design something that is so graphic oriented to be compatible with the standard graphics drivers out there. Zwift support continues to suggest updating to the latest graphic drivers to fix the issue but that only makes it worse.
Thanks for the updates and fixes. You guys are doing a great job so keep it up!
Are you kidding me? Cotacted you about going off course whilst doing the Uber Pretzel, you blamed it on me doing a U turn which I knew I hadn’t done and all along there was a bug?
Is this considered a major release?
I have the same or a similar problem. The resistance is opposite. Going uphill gets easier and vice versa.
Thanks ZHQ for all you’re doing to help keep me active during lockdown. I love the platform and what it does. Only request, and perhaps I’m not the only one, please can I stay in world when I finish a ride?
Great job. Thanks… Praying for the end of Sticky Draft
The bug that was fixed, I assume, was the one introduced recently on the wattbike atom when paired for steering it caused your avatar to go in circles, constant u-turns. I don’t think there is a bug that causes u-turns other than the wattbike one.
I too, hace an issue where Zwift won’t pick up my HR from my Fenix 5, while on my wrist.
The Fenix 5 ONLY broadcast HR in real-time in ANT+ and Zwift for iOS is Bluetooth only.
Thanks for the update and a special thanks to the developers for their hard work.
Thanks for the reply.
And a 100 other massive hugbears …
but instead we see a fix for users logging in with archaic versions get wrong message viewing new worlds.
Why is that even a problem what error they get , especially since we get a new world every year at most but deal with plenty things on a daily basis that is just not prioritised . Something is not working here in there ability to deliver customer focused prioritisation and just fixing simple and daft edge case nonsense.
what about support for Wahoo Direkt Connect ?
What does this involve as since thsi update my name as now showing incorrectly . My Team Tags are removed in nearby list , even though they are correct in zwift .
