Game Update 1.46 [August 2023]
Also another issue discovered. I often do Picture in Picture on my rides and with this update the power and cadence drops as soon as I hit the Control Center button. I suspected this yesterday and tried it 8x in a row and each time my the power and cadence dropped out. I am using a Kickr Bike with Apple TV 4K WiFi 64GB
Power dropout 2hrs into my 3hr ride. Please look into this!
It would help tremendously if you would provide some information about your setup, instead of just a screen photo.
Looks like you have steering enabled. If that’s Zwift Play controllers, there are a lot of reports of Bluetooth problems with them paired. There are several threads on that topic.
This was mentioned in the previous post. Kickr Bike on Apple TV 4K
Kickr Bike
I am having the same exact issue. Only the right zwift play keeps connecting and disconnecting and displaying a message saying disconnected. Then it connects again where i can use it for one ride on then it disconnects again. The left one is working fine. This was no issue when i was using Apple TV and the companion App. But when I switched to windows it start happening.
Any solution yet?
Hossam,
The disconnect issue for the play controllers has stabilized in my situation. I added a USB extension cable to the BT dongle on PC that moved it less than 24" away from the controllers. Since then, I’ve they have stayed connected and while I still see occasional disconnect messages while zwifting, it reconnects immediately and continues to work during the ride. I’m on the latest version of Zwift & controller firmware is up to date.
While I was experiencing disconnect issues, I just left them connected via the power cables and that seemed to stop the disconnects. Might be an option for you until Zwift solves all the nuances of this issue for different configurations.
Thanks a lot for your reply. Do you mean that you keep the charging cable plugged into the Zwift play all the time?
I have the PC right infront of the bicycle and the USB is in front so nothing is blocking the signal and they are like 3 feets away from each other.
