Here are a few bugs. I’m running Windows 11, Bluetooth connection from PC to a Wahoo Kickr Bike and heart rate monitor.
Bugs new to version 1.40:
Steering is connected and enabled, but my avatar doesn’t actually move around when I press the steering buttons on the Kickr Bike. The auto draft placement is also bad. Many times, but not always, I am placed on the far right side of the road, outside of the group and draft. So that’s a big problem in races. I disabled steering, and the auto draft placement was working normally.
Bugs new to version 1.39 that I still notice:
I use full screen mode for Zwift, and I am no longer able to switch to another window like Spotify or anything else. Zwift just stays focused at all times.
Critical power graph in the ride summary no longer shows the vertical line and data points.
Supertuck - I think the effect was disabled in races, but other avatars (not my own) still appear to be in supertuck.
Bugs from months ago, not sure which version:
There are many downhill sections in different worlds where my avatar will stop pedaling for a few seconds even though I’m still pedaling.
After I finish an event, then join a pace partner, sometimes my avatar will not pedal visually, even though I’m moving at a normal speed with everyone. This continues for the duration of the whole ride.
I have switched back to Bluetooth instead of Ant+, because after a certain Zwift update that I can’t remember the version of, I started getting Ant+ dropouts for about 1 second of 0 watts, but then back to normal watts. This happens consistently at least once every couple rides or up to two or three times in a single ride (my rides are usually 90 minutes). I never had this issue before that update, so I’m just assuming that Zwift update started the problem.
@Jonny_P1@Gerrie_Delport_ODZ
The copy paste issue has been fixed in game version 1.41, which is rolling out over the next couple of days across all OS platforms. Please update when it is available to you.
Few new Issues identified in 1.4 Note: I am not sure if this mentioned (its a long thread)
“Fixed an issue where Kickr Bike steering could not be disabled” - I can confirm i see this fixed but i am seeing a few new issues as a result.
#1 I am still being forced out the pack to the right on group rides (randomly), But a new development, i do rejoin the if you turn to the left. Ie am out the draft (On the right) for a section of time till the rod turns left then i rejoin
#2 If i use the Coffee Stop then the Kickr Bike Steering stops working (Yes it one but its break again if you use Coffee Stop)
Super long thread, not sure if anyone has had this issue.
I use Apple TV 4K for zwift, it updated tonight prior to doing the purple unicorn workout onto the latest level.
At the end of the workout I did a few more mins of freeride to carry on spinning the legs, but for some reason it doesn’t appear to have saved the activity but the xp is at the post session level.
