Has anyone see an iOS update available?
First ride with all updated worked perfect no problems at all but i noticed atv also had an update today which i didnt install could it be causing a oroblem for those on atv
As another data point.
Windows 10
Elite Zumo
Ant+ direct (not through ZC)
All working fine.
Sim mode is as usual.
ERG mode is adjusting resistance. I let myself get into an ERG hole with very low cadence, whereupon ERG mode disabled itself, I spun up and it switched back on.
Drops working as normal, including double drops with RoboPartner.
A post was merged into an existing topic: Trainer Resistance | Trainer Difficulty too low, Simulation and ERG mode do not work [January 2023]
A post was merged into an existing topic: Drops counter stalling and frozen pedestrians [Jan 2023] [1.33]
Yup. Broken for me as well. Original kickr connected via ANT+ FE-C, quarq, hr. PC running windows 10. All worked until 1.33 update.
Also drop counter only sorta works.
Real stinker of an update.
2 posts were merged into an existing topic: Trainer Resistance | Trainer Difficulty too low, Simulation and ERG mode do not work [January 2023]
Crashing mid-race - on a previously completely stable system - thanks.
May I ask why your update procedure on Windows is still completely broken? On Startup, it shows update⦠A progress bar pops up underneath the image, runs to the end, then disappears. Then nothing happens. Then you manually have to close this startup screen and start Zwift again. Then a small dialog pops up saying again that thereās an update. You click ok here - then a Windows Admin screen needs to be acknowledged⦠Then it works on somethingā¦
After that an error pops up, telling me something went wrong and Zwift needs to reinstall. A Windows Installer Wizard guides me through the setup process.
After that I can finally start Zwift.
This story is NOT NEW. For more than 2 years of zwifting this disaster has been going on like this.
Why?
Hi @Olaf_Gottschalk_AR, welcome to the forums.
I donāt have this same experience on my PC running Win 10. There was a new launcher update as well yesterday so the process was a bit longer than usual, but it has never crashed like you are suggesting on my PC. This makes me think there is a problem with your PC. Perhaps a clean install of windows and a reinstall of Zwift would do the trick?
I assume you were still on a very old launcher.
Did two Alpes today and got a āNew PRā on the middle of my second ascent⦠ZCA shows some unknown PR at 2.33 seconds Guess they didnāt test multiple ascents
BooX
Yes. I downloaded to iPad in Australia over 12 hours ago.
As iOS updates can be region specific (different servers for different countries/regions) it might be helpful if you posted what country you are in.
No, I am on latest versions. Zwift forces you to update, there is no chance to stay old.
And nothing crashed. Itās just completely silly and incoherent the way updates are handled by Zwift - and this has been like this for as long as I use it.
Worked perfectly on mine today when i updated.
It must be something localised.
Are you running anti-virus software?
Sigh. This is not anti virus software related. This is the usual terrible testing on each release.
Thank you. USA and it just came through for me as well. Ride On!
Never heard by anyone of this kind of problems with a Zwift update
This caused a kind of reinstall of the Zwift launcher this time.
Thanks for that valuable input.
I assume you have extensive knowledge of the posters setup to who i was replying to?
