This has always happened as far as I can remember.
On iPad and ATV (my first three years on Zwift), it was definitely different: Companion map screen only appeared when the route/ride/race was launched. No map during home screen selection.
Maybe it’s always been like what I described on PC? I can’t recall what PC with old home screen was like, as I only had that for a short time and my PC experience was new and different, so I didn’t concentrate on Companion’s behaviour.
I think it’s a semi recent change - sometime in 2022. My recollection is the CA used to sit at the screen as if you weren’t on a world until the world actually loaded and you could ride.
Thanks for reaching out! I’m sorry to hear you have run into this issue, but we are here to help!
After looking into your account and your computer, it seems like you are experiencing issues consistent with the Intel integrated graphics card issue explained in this forum topic.
I’d like to follow up with you via email to discuss this further, so I’ll be sending you a follow-up email shortly with more information. Thanks!
Thanks for this. I received a firmware update from zwift today and ran the program and entered an event and load times where way quicker and no crash but still maybe the load time could be increased further. I have done another re-install of windows 10 today, since my ride. I will then login to the game and set the game resolution settings from the medium setting to the low setting and hopefully test again tomorrow. Thanks for investigating this and acknowledging the possible issue with the 10th and 11th Gen Intel CPUs with integrated Intel GPUs.
I have had 2 succesful rides in the past 2 days. Both on Low game resolution and the load time was better. However on the low game setting companion app doesnt seem to want to interact. I moved it back to medium and companion app chnaged to game mode and i could interact with my fellow riders.
I made the changes and went to the lowest game settings. This was better performance but the companion app wouldn’t connect. Since the last update i have moved back to the middle game settings and the load time is better but most importantly no crashing. Thanks for the tips.
The game resolution setting shouldn’t affect load times unless your system is extremely unsuitable for Zwift. It certainly has zero bearing on the Companion app.
Hi Dave, thanks for your input. As Zwift support themselvels reached out, as seen above, and in a personal email to me, acknolwdged that there is a ‘known’ issue with certain intel integrated graphics cards they themselves advised to chnage the game settings and it DID improve load times.
you said further up the thread that you had changed the resolution down to the lowest and it was still taking 15 minutes to load. Did you change anything else might have just been coincidence that it worked when you changed the resolution.
That issue for 10th and 11th gen iGPUs relates to the game randomly freezing up, which may well be improved by lowering the load on the system via a lower resolution setting (not that you should have to accept a worse experience to make it work), but if it’s also significantly improving load times then something else isn’t right. Let’s Go to the pairing screen should be well under a minute no matter what your settings are.
I see you’re in the UK, happy to fix you up a dedicated rig if needs be. Drop me a message if you’re interested.
