Everything was working fine during the warmup period with ERG mode. The resistance responded as expected. But once I got to FTP test the wattage/resistance was stuck at 130 watts. I couldn’t increase through a higher cadence, through switching gears, or by using the manual resistance increase button in the Zwift mobile app. Very frustrating. This was with Wahoo kickr trainer.
i’ve done this previously with similar setup no never this problem before.
I’ve seen reports of resistance dropping out completely but never one where it just maintains a steady resistance. This info will help us pinpoint what’s happening.
To clarify, the resistance would drop below 130 watts if I slowed cadence, but it would not go above 130.
I use the Zwift iPad app, so the Kickr is connected via bluetooth. Looks like I was not on the latest Kickr firmware. I was on v3.2.51 at the time. Subsequently, I’ve updated to v3.3.53.
Just tried again and still an issue. I wonder if only way to get to work is disable ERG mode and then manually adjust wattage and resistance through gear shifting?
Disabling ERG mode for the entire workout would probably let you work through this, but the underlying issue is definitely a bug.
I’ve made an email support ticket for you from this thread, so keep an eye on your inbox for more updates. If anyone else is experiencing this, you can also submit a ticket. Thanks!
Having the same problem with my Kickr 2, zwift did seem to reset my ftp to 100. I slide back to 210 and started workout in erg no problems until I hit the test phase, then couldn’t get wattage over 115 no matter what I did…
Did spindown test tried agin in both normal and erg mode, no difference I have the latest firmware on all my kit i.e. MacBook Pro and Kickr 2
I also experienced something similar to this just now doing the FTP test. Also on the Wahoo Kickr 2. I was using my Quarq Dzero as the power source and and Kickr as the controllable trainer. The previous intervals in ERG mode worked fine however once I got to the FTP test phase the resistance wasn’t set high enough so even in my biggest gear 50x11 I wouldn’t push much over 250 watts.
To add I had had the current mission (training peaks workout thing on before I started the FTP test).
I then closed everything bluetooth related on my phone. Started again with the FTP test and skipped a few of the initial intervals as I didn’t want to do them again. I did 6 minutes easy watts just before the FTP test then when I got to the FTP test it worked!!
Could it be something to do with the current training peaks mission and the FTP test? As that seems to be the only thing that changed between the two attempts.
Had the initial issue listed at the beginning of the thread happen to me today. Regardless of the gear I was in or how high my cadence was, the Kickr adjusted resistance so that I was always at or just below the target wattage. I sent a ticket in to Zwift tech support a little bit ago. Hoping to get an answer soon
I have exactly the same problem with FTP test yesterday. I also have a wahoo kickr powertrainer (new version 3) and I’m connected bluetooth to Zwift by an iMac. Building up / warmup to the real FTP test was no problem - took about 43 minutes. But when FTP test starts watt resistance was stuck on maximum 105 watt regardless my gear switching or cadence speed.
to your information my settings in wahoo fitness app is:
I am having the same problem. Kickr snap 2017, zwift on iPad, can’t get above 110w. Haven’t tried the work around above. Has anyone else? Does it work?
