FTP results
I just took an FTP test in Zwift. How do I see the results and where can I go for the analysis?
Need Help!
The result will be recorded on your in-game profile. This documentation explains how to view or change it:
As for analysis, you should not use Zwift for that. Link your account to a third-party analysis app such as intervals.icu, Garmin Connect, Strava, TrainingPeaks.
If you did one of the Zwift FTP tests (ramp test or 20min test) it should tell you the result right after doing the test. It will also update your FTP in your settings if it is higher than the one that was set previously. So if this was your first FTP test you should be able to see what the FTP was in your profile settings.
Edit: Paul was faster than me
