Fitbit sync broken?
Every time I link my account to Fitbit, it syncs once at the time of connection, then never again. If I open my account page later, the connection is no longer active and I can go through and do it again - for a single sync. I don’t think my account has been google-ified - as far as I know it’s a plain Fitbit account, at least for now.
This used to work reliably for quite a while, but for months now it’s been like this - with maybe occasional periods of proper operation. I’m honestly not sure, I have almost given up on the idea of keeping my weight accurate at this point.
Does this work reliably for anyone else? Is the Fitbit integration going the way of Withings, which stopped working for years and was then quietly dropped?
Hi Jonas, welcome to Forums. I’m Juan part of the Zwift Support team.
Thank you for posting your concern here. I understand how discouraging it can be to sync both Zwift and Fitbit each time. Don’t worry; we are here to help.
I see that you’ve already reached out to Zwift Support via email regarding this issue. To ensure you get the best assistance, I’m connecting you with the right Community Support Colleagues in Zwift Support who will be able to help you further.
Please continue the conversation via email, and they will provide the necessary support to resolve your syncing issues.
Yeah it’s not working for me either…sometimes i get 2-3days of sync and then i have to relink the account again. This has been going on for a while. There is a few posts about it from last year.
Hi @Jonas_H and @DejanPresen, Thanks for the updates!
I’m Fernanda, from Zwift.
Could you please make sure to check your Fitbit app and ensure that the data access for the Zwift app is set to “allow all” instead of “weight only” as in the picture below? Based on previous experiences of other Zwifters, this step may help resolve the issue you are facing.
Please give it a try and let us know if your weight is correctly synced with Zwift once more.
Keep us posted.
The connection already shows access to weight, profile, friends (see below). Interestingly it shows as Approved on March 27th, while I have re-created the connection several times since then. When I reconnect I am not shown the dialog you post (though I have seen it in the past). It simply goes to the Fitbit site and redirects me back to zwift.com instantly without any interaction.
I should probably also correct my first post. I’ve paid closer attention over the past week, and I do (at least sometimes) get more than a single sync. As Dejan says, it seems 2-3 days is about the limit.
So a short update the last week or 10 days my updates happened without me needing to reconnect FITBIT.
Did you do something to fix it?
@Juan_Lopez10 the problem is still active. I have tried also to remove the connection and connect again to Fitbit with all available data access. One time the sync works after reconnect. Nex day, the connection is grey in settings again. Could you please help me? Thanks, Ride On!
Exact same problem for me.
One sync, next day the connection is grey, and need new connection.
Anyone at Zwift able to fix this?
Things seems to have turned slightly worse: Most recently, the connection looked like it was active (i.e. the logo was in colour, and the link below says “Disconnect” on my.zwift.com), but updates weren’t coming through.
Any hopes to get this fixed?
still no work about this problem? I’m suffering from this problem still regulary since May 2024, while I regulary pay for my zwift account. very funny.
Fitbit sync hasen’t been working for about a week now. It doesn’t even sync when you connect the accounts.
I’ve noticed this subject kicking around for a while, would it be possible to have an indicator on the integration page to show when the last successful sync for any connections, perhaps just a date field that is written after a successful sync, and maybe an red X to indicate an issue?
I’ve had the fitbit sync active for a while but feel I need to regularly check it, perhaps an expansion on the above would be a notification and/or email to advise of a failed sync.
