Shuji at Zwift HQ here. I’m peeking through your server logs for clues.
Q: You’re talking about a ride you did the same day you wrote in, yes? I’m seeing you logged in / logged out of game 5 times that day, and only the final ride was long enough that it was saved to your activity feed: the 6.7 km ride on Flat Out Fast route where you chose the VO2 Max INEOS Grenadiers: Anaerobic Capacity workout, please confirm that’s the one in question?
It looks like you may have been trying different routes to see if they looked like something you wanted to do, then you changed your mind and tried another. Is that what was happening on your end? It’s possible that something didn’t load correctly in that sequence of logging in / out.
Would like to ask your for some context that’s not captured in the logs. Are you in the habit of leaving Zwift running on that PC once you’re done, or do you shut down the app and also turn the laptop off? Would you mind trying to reproduce this glitch by:
Power off your PC and rebooting.
Log in to Zwift
This time - go straight into that VO2 Max INEOS Grenadiers: Anaerobic Capacity workout and select the Flat Out Fast route in Watopia.
Does the workout load correctly into ERG mode? Please take a screenshot with the camera icon in the Action Bar across the bottom if you’re not seeing the intervals across the left side.
One other thing in your case: your machine was on game version 104.4 that day (Jan 19). The session before, it was on v105.2. My guess is that the game rollback we did last week may have had an impact here. It’s possible that rebooting / logging in fresh to Zwift might purge some cached data and clear this up.
Looking through your server logs, I can confirm your mac is on game version 1.105.3 and your iPad is still on v 104.4 as of today.
Q: I noticed that you updated the firmware on your Zwift Play from v 1.0.0 to 1.3.0. Did that make any difference for the ERG mode situation? I suspect not.
For the same reason as James (to purge the app cache) - would you also try powering off the Mac and rebooting, and go straight into the 90+ minutes to burn Week 1 Red Unicorn workout again and let us know if that makes a differnce?
I will note that while you were troubleshooting by comparing Mac to iPad - you correctly logged out of one before you logged in on the other. That is a known pitfall that I’m glad you avoided. Please continue to use care to avoid simultaneous logins on more than one device.
