I’m confused about the Computrainer setup. I understand that I don’t want to use my Ant dongle when pairing the Computrainer as it does so via the USB Com port but what if I want to pair my Garmin HRM while riding? Do I unpair my Computrainer and pair the HRM? If I disable the Ant I lose my HRM but if I plug it back in I can’t get into ERG mode as the Ant dongle seems to override the USB port signal of the Computrainer…confused.
Sorry for the delay regarding support tickets - we are absolutely swamped by them right now. Regarding your Computrainer - the CT itself doesn’t need ANT+ as it’s plugged in (correct), but you need one for your HRM.
You do not need to unplug them - they will work concurrently. So go ahead and plug in the ANT+ dongle and your CT at the same time and you should be good to go.
