Elite real e-motion rollers
Hi!
Is there any help for my old real e-motion rollers? The problem is on the flat sections. The issue is that on flat sprints and down hills i allways run out of gears. Resistance is too low. But on hills resistance is ok and i can sprint way over 1000watts. trainer difficulty option doesn´t effect on this problem.
Thanks allready
Jarkko
Hi, how did you setup the trainer? I use the default choices of zwift (power meter, cadence and controllable set to real fec option)
I think i have the same trainer as yours (elite real emotion v1 of 2011, recently updated firmware to b+ version to support standard ant+ with fec), but for me resistence seems to be controlled (strong) only manually when i select a training plan (i.e. i set manually at 600w), and no automatically on hills.
On the contrary, on flat my resistence increases with speed (over 30km/h is quite high)
Thank you,
bye
Gabriele
actually now those rollers broke down and I was forced to buy elite direto xr… but I have to say that I like rollers more than trainer. bike is free and down get chance to broke the frame. also ride feel is much better on rollers
Thank for your answer
Jarkko Niemi
Team Continental-Focus
Bringing this Ine back to life…:
Two problems with this. One trivial.
It over reports watts, not a biggie as I use power meter
Worse…When Zwift controls it, it does not add enough resistance and I spinn out to .
That would be a Zwift issue as it works perfectly fine, or better, with Elite my E-training and others.
Any suggestions ?
Hello. Can u tell me how u update your ant firmware to suport ant+ fe c. Zwift only recognize my cadence and speed sensor.
I have Elite real emotion rollers Ant wireless 2014 year serial number 50331
Elite has an app called “Upgrado” which is used to update the firmware on most of their trainers. I don’t know if it works with that one, but that’s the first thing I would try. Second thing I would do is contact Elite support.
Hello Gabriele. I have Elite real emotion trainer 2014 year. Product number 50331. Its ANT only. Can i upgrade formware and how? Thanks
Thank u Paul. Upgrado works only with Bluetooth. Mine trainer is AnT only. I heard that there is some way to upgrade AnT protocol to AnT Fe C but dont know how. I see Gabriele somehow do that thing. Thank u for sour answer
