Duraace R9200-P loses power numbers but still connected to Zwift
Twice happened and couldn’t get power reading back on. Was riding the Zwift - Group Ride: Standard | Stage 2 | Tour de Zwift on Temples and Towers in Makuri Islands and about 14 minutes into the ride the power readings drop to zero and I’m dropped from the group. Tried to reconnect but found the power meter was still connected. Disconnected it from Zwift and reconnected but still no power readings. Have to exit Zwift and reconnect to regain power readings. Anyone have a similar issue after the update? Now if doesn’t register any power reading at all even if I reset Bluetooth connections
What are you connecting under resistance?
Yes I pedal to wake-up the power meter and keep pedaling when connecting to Zwift. I checked the connection on the left crank arm and wiggled it at bit to make sure it was connected well and that seems to have resolved the issue
