Garmin power meter issues
What is going on with Zwift’s ability to connect to Garmin vector power meters?? Yesterday my power numbers were way high. Today I can’t connect the power meter to Zwift at all. Won’t show up. Heart rate strap gets picked up fine so it’s not an ANT issue
What is going on??
There hasn’t been widespread reports of this so I’d so it’s maybe something specific to your setup.
If you have had erroneous readings followed by them no longer being detected I’d hazard a guess as to say that maybe it’s an issue with the pedals. Battery charged?
Can you connect them to any other device? Or software?
Hi! Thanks for the reply. I ended up recalibration the pedals and that seems to have done the trick so far. Should probably change the battery too
Thank you! I really appreciate the reply!
