Good day. I’m trying to make sure all is good with my indoor setup and am learning how to dual record so I can be in compliance with some of the races. Currently have my primary power as my Kickr Core with my Quarq or SRM as my secondary. When trying to create a data set to analyze I am exporting the power file from training peaks and it exports as a .fit.gz which Zwift Power doesn’t seem to like and is unable to analyze. When I compare my Kickr to TrainingPeaks data they are with 3-4% of each other.
I made the same with Tacx Neo and P2M powermeter, difference max. 2%.
Used the original Zwift fit-file, second power source recorded with Jepster Android App. Jepster fit-files were always OK.
I use a slightly different setup as my 2nd meter is connected to my bike computer. I auto-sync the activity from the bike computer to Strava, and from there "download original " to my PC. That’s the file I use for dual recording on ZP. It’s a bit of a workaround tho. If no more useful answers pop up I could try and figure out the file extension I’m getting from Strava later.
I think I got it all figured out. I had to use a file converter as my pc didn’t have the ability as it is locked up (work 'puter)…
Thanks to everyone who responded.
I was surprised when I found it - it gets all infos from my P2M powermeter, including left/right analysis and I had never problems with the files.
Can run in background with no issues.
I had the problem that when I downloaded the .fit from garmin connect, the powerdata is different then in the file from the edge itself. This only happens when I use a powermeter that allows to view balance or other cycling dynamics metrics.
Did anybody noticed the same issue so far?
