Drunk camera operator
Does anyone else have a drunken camera operator in control of the screen when riding.
I have noticed since last update that when im riding either on my own or on a group ride, that as I cross various junctions the screen sways to left and right.
It’s as if there is a dunked drone camera operator in control of the screen.
It’s not the rider that moves but the camera view from side to side. :thinking::movie_camera::winking_face_with_tongue:.
I have a new bug with it rocking front to back in camera 1 and 2. Very annoying
It could be the “springy” camera setting.
Thank you!
You’re welcome!
So this worked but also raises a number of questions
There is a tree drawing setting … is that all I needed to do to get trees back?
What is AI Rider number ?
How many other settings are there and what’s the best set up?
I recommend not messing with those other settings, since doing so can easily make your setup very unstable. Or you might find that you change something and it works fine, but then a few updates down the road it breaks and you forget that you changed that item.
There is some info in this article.
If you’re on a PC, you can also check out the files on the ZPCMR group on Facebook to understand how the refresh rate can affect that rubber banding effect. I have also seen it on a MacBook Pro when refresh rate was set to ProMotion, went away when set refresh rate was set to 60Hz.
Useful stuff, thanks!
