Drafting indication
I realize that my avatar reacts to drafting, namely it sits up when I’m in the draft. However, I never see anyone else sitting up. Is this only visible on your avatar? I believe that drafting benefit increases in larger groups but there’s no indication that people in front of me are drafting, their avatars are always low.
It is only visible on your avatar.
From ZwiftInsider:
Zwift uses the visual cue of sitting up as an indicator that you are in the draft. It can be a little confusing though, since Zwift will also have your avatar sit up at slow solo speeds.
Thanks, that clears it up, I was even trying to figure out if people were riding Tron or TT bikes around me and that was the cause.
