The topic “Direct Connect Issues [October 2025]” has been marked as solved.
I can tell you with 100% certainty that it is not.
I use Apple TV4K and a KickrV6 with DirCon.
I had abandoned using Direct Connect for a couple of months because of the repeated failures, but decided to try again last week. A few workouts were fine with no issues, but today, ~eight minutes into a two hour workout (using ERG), ERG disengaged and I could not get it to reengage. I then used the Companion App to pair over BT, but once I did, I could not reengage ERG, nor did I get any resistance with virtual gearing. I had to end the ride and start over again using ZCA as a BT bridge.
I, along with others can confirm that this issue has not been fixed.
Please get this resolved.
Thank you,
Peter
