Since the latest release, there are three new issues I’m experiencing with Zwift Run (using a Zwift run pod on ATV 4th gen):
The “Select a goal” button at the top of the HUD (where you can select time or distance goals) can no longer be accessed. Swiping up, left, right, down - nothing gets the cursor up to highlight and select the button to access the goal options.
Bluetooth connectivity dropping out at a frequent rate (yes, full battery, on same network and all the other usual suggestions/checks). When I try and re=calibrate the run pod, it can’t even hold a bluetooth connection solid for 40 seconds.
Speed is now wildly inaccurate when just days before it worked fine. Can’t recalibrate - see #2. above.
