My wife and I both belong to Zwift, and we typically cycle together. However, we don’t always get started at the exact same time. Is there a way to immediately jump to the other person’s spot so that our avatars are at the same point in the course?
If you are ‘friends’ on Zwift, and even better if you are ‘favorites’ of each other, the second person to join should get a ‘Ride With’ option on the world selection screen when they log in. They would then just select your name and they should be put right with the other person (as long as the ‘ride with’ person is not in an event).
This might help, too: Swift Zwift Tip: Join a Friend For A Ride - YouTube
Thank you, will try out for this evening’s ride!
Updated; worked perfectly well, thanks!
