Hi @Mark_Parker2 ! I see how important it is for you to create your workouts, and I value the time you took to confirm that the option is also missing on your other devices. Could you please verify if you’re not in running mode? Workouts on Running Mode only give us the option to select one of our pre-made workouts or import a custom TrainingPeaks™ workout. If you are in running mode, you can switch to cycling by following the steps in this article. Once you have switched to cycling, you will be able to see the Custom Workout feature on your PC and iPad. However, please note that this option excludes Android phones. For more information, please refer to this article.
