When i look in my stats of Strava, i climbed 25 times the alp du zwift. But i didin’t get my badge yet. Where can i see, how much i did regarding too Zwift. I probably finished one time in my free 25 km of the month. So i suppose Zwift doesn’t count these rides. But how can i be sure? Another suggestion : For me it’s hard to know if i can ride a sub hour climb or not. Maybe it’s not necessary to have a clock on alp du zwift, but maybe it would be an idea to have the number of marmots (same as the minutes you can ride under an hour, regarding your actual pace) at the half of the climb :-).
I checked mine, only lists three though I know I’ve done AdZ almost 20 times now
Got a screenshot showing the three?
Any chance you did multiple of those 20 ascents on the same ride? If so, it’s possible you didn’t go far enough at the bottom to ‘reset’ and start a new climb.
The segment is AdZ, not Fire and Ice etc. lol, and no multiples
I checked again, 3 PRs - 17 times when I read the fine print
Within touching distance… up you go. ![]()
One thing the companion app does miss is the total times you’ve done a segment. It could show that as well as quarterly (what it gives now).
Strava is good for the absolute total.
I followed your advice and indeed zwift also says I did the climb 25 times. But no masochist badge till now.
