My setup is wahoo kickr and quarq dzero running latest firmware And Apple TV . Everything worked great until zwift changed and I need to used zwift companion for all BT connections. For some reason when I run power meter as source through companion app the power stays constant when I stop peddling.
I could sprint for 800 watts and stop and it would ride me around the course at 800 watts.
This is not an issue if I don’t use companion app but then I don’t get all my connections.
I’ve seen one other post w same issue. It does not appear to ever be resolved.
I’m running latest firmware and app updates on everything. This has been an issue for awhile. I’m finally submitting it to see if there is anything I can do. Thank u
