i have an up to date PC with Asus Rog Motherboard, RTX4060 Ti video card Wifi, and built in Bluetooth.
when i go to connect to the PC, though bluetooth, under advanced settings windows 11, it won’t connect, but if i plug an ant stick in it reads it, and my HR Strap.
Is there a way of isolating the connection through bluetooth first?
and having it show as a connection, in the settings menus?
Is this a Zwift or Wahoo issue?or kinda both
You don’t pair Bluetooth devices in the Windows settings. You just launch Zwift and let it handle the pairings.
If your built-in Bluetooth adapter isn’t getting good signal, it can help to put the antenna on an extension cable if that’s an option. You can also upload Zwift log files to zwiftalizer.com to get insight into Bluetooth connectivity problems.
