I’m using an old Tacx Flux trainer. Has been working OK until last update (1.49.0). After about 10 min och cykling I get “Connection Failure” for about 30 sec. I have the same problem both with Mac OS and IOS (Apple TV). Anybody else experieceing the same issue?
/Johan
Force close the app and reopen it. (you should also force close the app after every ride - not every session, every ride)
Uninstall the app, restart your device, reinstall the app.
Failing that (at least on the AppleTV), do a hard “Reset and update” of the whole device before reinstalling the app.
FWIW, I had the “Connection Failure” (signifying a sensor disconnect) the other day. Force closing the app and reopening did the trick.
Another possibility is wireless interference. There is a support article with some tips for troubleshooting that. You could also try testing the trainer using the Tacx app.
