The HR strap should connect via ANT+. I am pretty sure that it is ANT+ only, so that’s your only option.
Perhaps try a diff USB port for the ANT+ stick. Also verify that your MacBook sees the ANT+ stick. System Information > USB. You should see the ANT+ USB stick listed. If not, you have a problem.
Thanks Lin. Yes, the ANT+ USB stick is listed. I did manage to get it working today, but it’s been a bit hit and miss. Turning my 630 off seems to have helped.
