Robert_K
(Robert K)
1
Hello,
I have classic trainer without any smart options. I’ve got ANT+ sensors : cadence, HR and speed.
I’m using SONY Xperia Z5 Compact with ANT+, when I’m using Strava for example all sensors can be connected with my phone.
I’ve installed Zwift on my PC and also downloaded ZML on my mobile.
How should I connect all the devices to use ZWIFT ?
Zwift on PC sees the ZML, they are connected, but when i try to search for sensors, I do not get any results.
Right now I’m using trial version to check if it works, but I would love to get the full version.
Thanks in advance.
Robert: you need an ANT+ USB dongle for your PC, like the one Zwift sells in their shop at this link: https://shop.zwift.com/products/zwift-ant-starter-pack.
There are others ANT+ USB dongles, like the Suunto Movestick Mini, that work with Zwift and are available at retailers.
Robert_K
(Robert K)
3
Thanks for your answer. I thought that i can use my phone as a some kind of transmitter
You’re 100% percent sure, yes ?
Robert,
The ZML can be used as a bridge for Bluetooth devices, not ANT+ so you would need an ANT+ dongle for those.
