Companion fails to add to calendar
The companion app claims it needs full access to add an event to my iOS calendar, when my settings are set to “Add events only”. This setting should suffice for adding events to the calendar. I’m aware Zwift won’t be able to remove events from my calendar with this setting.
Same issue here. It got worse after reinstalling the app, as now the app does not show Calendar access in Settings.
Yeah, same with me
Same here, both on iPhone 14 Pro Max and iPad Air 3.
iPadOS 17.0.2 and iOS 17.0.2.
Full access is granted. App version is 3.51.0 on both devices.
Same here. I don’t want to give ZC full access to everything in my calendar. Please make ZC work with ‘Add events only’.
3.51.1 is working fine again for me.
I changed my settings to “ask” and now it works as before
Same here on ios 17.0.2 and 3.51.1 app version
