Hi all
Using zwift on a PC and companion on an Samsung Tab S8.
Always worked perfectly until the last few weeks. I nearly always get the GAME screen but the map often doesn’t update, is very slow to update or even has the wrong world.
I’ve got both on the SAME SSID (although used to work perfectly with PC on Ethernet cable directly to a different router). I’ve closed the app, cleared all data, uninstalled and it’s the same.
Sometimes I only get the leftmost buttons across the bottom.
I can often give ride ons even if the map hasn’t updated my location.
I’ve tried the tips on Zwift’s support page but it doesn’t help.
Any ideas?
Si
Erm… Fixed this… Odd issue I think with a 2nd router used to extend the network using a subnet
