COGV2 provided with Zwif Ride frame
Hello!
I bought a Zwift ride frame, which was delivered with a cog V2 without a freewheel. I have a Zwift hub home trainer with a cog V1 and therefore a Hyperglide freewheel.
The cogV2 doesn’t seem to be compatible with this freewheel, is this normal? Is the COG V2 supplied only compatible with elite home trainers?
Thank you in advance for your help!
The Cog you bought is compatible with your trainer. Did you remove the plastic carrier that the new Cog came mounted on? It should be a clear plastic tube that you need to remove.
Thanks! I wasn’t properly aligned, that’s why it didn’t work.
My freewheel is damaged, do you know if all HG freewheels fit the cogV2 / Zwift ride frame configuration?
I assume you mean the freehub. Freehubs are not all interchangeable. I recommend contacting Zwift support, tell them you bought a ride frame but you need a new freehub for the Zwift Hub. They might give it to you. If not, you could buy the Cog + Click upgrade that comes with the multi-trainer freehub. That freehub will work on your trainer. You would end up with an extra Cog and Click, but you could probably sell those if needed.
OK thank you very much Paul!
